Webcast-Catalyst9k
Load Balancing
i have a 2821 router, is it capable of load balancing and if so, where can i find the commands?
1 REPLY
Silver
Re: Load Balancing
Most routers can, and you don't need to specify any commands.
Give it 2 equal costs path's and it will load balance out of the box.
Cheers,
Michel
117
