Community Member
Logging commands not incorporated to 12.4(7) ??
I am trying to filter out certain log messages from getting entering my log but the commands I want aren't integrated any reasons?
The command is logging buffered filtered
Logging filter isnt in there either.
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124cr/hnm_r/nmg_02h.htm#wp1052854
AM_1_IDC(config)#do sho ver
Cisco IOS Software, 2800 Software (C2800NM-ADVSECURITYK9-M), Version 12.4(7a), RELEASE SOFTWARE (fc3)
System image file is "flash:c2800nm-advsecurityk9-mz.124-7a.bin"
AM_1_IDC(config)#loggin f?
Hostname or A.B.C.D facility
AM_1_IDC(config)#loggin buffered f?
% Unrecognized command
Re: Logging commands not incorporated to 12.4(7) ??
The Embedded Syslog Manager is not supported on the 2800NM platforms. It is only supported on the 2801 routers (from the 2800 series). I am uncertain why support was omitted from those other platforms.
Sorry, I missed the platforms in the Feature NAvigator list. ESM is supported on these platforms, but it requires SPSERVICES or better.
263
