07-28-2006 05:22 AM
Let's say the router is configured with:
logging 10.1.2.3
logging trap errors <--this is level 3
Will the command 'ospf log-adjacency-changes' allow the level 5 message shown below to be sent to the syslog server?
%OSPF-5-ADJCHG:
Solved! Go to Solution.
07-28-2006 06:05 PM
The logging 10.1.2.3 and logging trap errors commands work together. The first one just says send syslogs to this address, while the second only allows messages at error level or below (0-3) to be sent to that IP address.
The message will not make it
07-28-2006 06:52 AM
Only the messages level 0-3 will be sent to the syslog server.
07-28-2006 09:25 AM
I opened TAC case 604054881 on this same issue -
What the TAC engineer told me was this:
if the router is configured with
logging trap errors
and the command
ospf log-adjacency-changes is issued
the %OSPF-5-ADJCHG: message would in fact make it to the syslog server.
Can you please verify because, I need to be 100% sure before I go back to the customer.
Thank you very much
07-28-2006 09:42 AM
I looked at the case and the engineer said the same thing that I mentioned:
If you have logging the level 3 you wont get messages from level 4 (or higher)
07-28-2006 09:44 AM
I think "ospf log-adjacency-changes" just logs it to the logging buffer on the router itself.
07-28-2006 11:12 AM
These messages should be sent to a syslog server if you have something like this configured:
router ospf 1
logging
--- provided you set the correct logging level
If logging buffered is enabled these messages should go in there, level is important here too
07-28-2006 11:33 AM
OK. I will inform the customer if the router is configured with
logging trap errors
AND has the
command entered in the config
The %OSPF-5-ADJCHG: message will not make it to the syslog server.
If this is NOT correct, please let me know.
07-28-2006 11:54 AM
I'm still confused:
if the router is configured with:
logging 10.1.2.3
logging trap errors
and has this statement configured
Will the %OSPF-5-ADJCHG: message make it to the syslog server
07-28-2006 06:05 PM
07-29-2006 02:18 AM
Thank you.
Sorry for the confusion but I have to be 100% sure.....
