logrot problem
I am trying to execute logrot script in order to delete some log files.
The problem is that nothing happened when I execute the script.
The configuration :
C:\Program Files\CSCOpx\bin>C:\Progra~1\CSCOpx\bin\perl.exe C:\Progra~1\CSCOpx\b
in\logrot.pl -c
Read config successfully.
Logrot Configuration Menu
1. Edit variables
2. Edit log files
3. Quit and save changes
4. Quit without saving changes
1. Edit variables
2. Edit log files
Enter option: 1
Number Variable Name [Variable Value]
1. Backup Directory [D:\backuplog]
2. Restart Delay [60]
q. Go back
Enter variable number to change: q
1. Edit variables
2. Edit log files
Enter option: 2
Number Logfile Name Number of Archives Max Size Compress
1. C:\Progra~1\CSCOpx\log\utm.log 0 100
a. Add logfile(s)
d. Delete logfile(s)
q. Go back
Re: logrot problem
According to this, you are only configuring one log for rotation (utm.log). Please post the output of logrot.pl -v. What version of Common Services is this?
Re: logrot problem
Yes, I have a problem with utm.log which grows too fast ... No debug is activated.
Anyway, I just want to delete periodicaly this file.
Below the logrot.pl -v :
in\logrot.pl -v
Wed Oct 8 10:10:23 2008: INFO: Read variable backup_dir --> D:\backuplog
Wed Oct 8 10:10:23 2008: INFO: Logfile = C:\Progra~1\CSCOpx\log\utm.log, Backup
File = D:\backuplog\utm.log
Wed Oct 8 10:10:23 2008: INFO: Archiving C:\Progra~1\CSCOpx\log\utm.log (file s
ize = 75517670, conf size = 2048000)
Wed Oct 8 10:10:23 2008: INFO: Rotating C:\Progra~1\CSCOpx\log\utm.log.
Re: logrot problem
According to this, utm.log was rotated. If the file size reverts to the previous file size, then this log file cannot be rotated while dmgtd is running. You will need to do an offline log rotation. To do that, pass the -s option to logrot.pl. This will shutdown dmgtd, rotate the log files, then restart dmgtd.
Re: logrot problem
Ok thanks Joe, I will try offline with -s.
156
