Looks like trouble
yjdabear
On a fresh install of Common Services 2.2 on a server that got the previous LMS 2.2 uninstalled, I keep running into the following. How bad is it?
First install:
/opt/CSCOpx/www/classpath/com/cisco/nm/nmim/nmic/banner.html
/opt/CSCOpx/www/classpath/com/cisco/nm/nmim/nmic/images/scenario1.gif
/opt/CSCOpx/www/classpath/com/cisco/nm/nmim/nmic/images/scenario2.gif
/opt/CSCOpx/www/classpath/com/cisco/nm/nmim/nmic/index.html
/opt/CSCOpx/www/classpath/com/cisco/nm/nmim/nmic/myFilenameFilter.class
/opt/CSCOpx/www/classpath/com/cisco/nm/nmim/nmic/nmim_getdb.html
/opt/CSCOpx/www/classpath/com/cisco/nm/nmim/nmic/nmim_getscript.html
/opt/CSCOpx/www/classpath/com/cisco/nm/nmim/nmic/nmim_nmidb.html
/opt/CSCOpx/www/classpath/com/cisco/nm/nmim/nmic/nmim_overv.html
/opt/CSCOpx/www/classpath/com/cisco/nm/nmim/nmic/nmim_register.html
/opt/CSCOpx/www/classpath/com/cisco/nm/nmim/nmic/nmim_start.html
/opt/CSCOpx/www/classpath/com/cisco/nm/nmim/nmic/nmimftpclass.class
[ verifying class <nmim> ]
## Executing postinstall script.
Post install script for CSCOnmim completed
Installation of <CSCOnmim> was successful.
application CSCOnmim Integration Utility
INFO: Configuring JRun properties...
syslog service starting.
INFO: the facility was not found in /etc/syslog.conf.
INFO: Checking permission for '/usr/bin/at'.
INFO: Permission of '/usr/bin/at' is 4755 - OK.
ERROR: unregister daemons "JRunProxyServer" failed. open registry file failed :No such file or directory
ERROR:save failed Open Registry failed, Error 0
INFO: CMFEnable.pl: wantSystem=0; wantNetwork=0;wantCore=0
/product/ehealth/backups/temp/cs22/postprocess: /etc/init.d/dmgtd: not found
Do you want to see the passwords that were entered/randomly generated ? If yes, please remember that passwords are security sensitive data and hence make sure they are kept secure.? (y/n) [y] n
Finished: Mon Nov 20 15:47:17 EST 2006
===============- Software Installation Tool Completed -==============
===================- Possible Warnings/Errors Encountered -===================
WARNING: Patch 110700-01 is OBSOLETE by a newer patch.
WARNING: Patch 108827-30 is OBSOLETE by a newer patch.
WARNING: Patch 111085-02 is OBSOLETE by a newer patch.
WARNING: Not a recommended computer model. Please refer to the
WARNING: prerequisites chapter of the install guide.
Do you want to continue with the installation of <CSCOmd> [y,n,?] ERROR: /opt/CSCOpx/setup/CSCOmd.info not found.
ERROR: GetProperty called with undefined package name: CSCOmd.
ERROR: mkdir -p /var/adm/CSCOpx/log failed. Config Dmgtd failed.
ERROR: setup data directories failed. See prior msgs. Config Failed.
pkgadd: ERROR: postinstall script did not complete successfully
yjdabear
Upon /opt/CSCOpx/bin/uninstall.sh
==============- Software Uninstall Tool Ended -==================
Un-install ended on Mon Nov 20 15:52:23 EST 2006
Host: SunOS nms 5.8 Generic_117550-33 sun4u sparc SUNW,Sun-Fire-480R
ERROR: unregister daemons "EDS" failed. open registry file failed :No such file or directory
ERROR: Could not unregister daemon EDS from daemon manager.
ERROR: unregister daemons "EDS-GCF" failed. open registry file failed :No such file or directory
ERROR: Could not unregister daemon EDS-GCF from daemon manager.
ERROR: unregister daemons "EDS-TR" failed. open registry file failed :No such file or directory
ERROR: Could not unregister daemon EDS-TR from daemon manager.
ERROR: unregister daemons "RmeOrb" failed. open registry file failed :No such file or directory
ERROR: Could not unregister deamon RmeOrb from deamon manager.
ERROR: unregister daemons "RmeGatekeeper" failed. open registry file failed :No such file or directory
ERROR: Could not unregister deamon RmeGatekeeper from deamon manager.
ERROR: unregister daemons "jrm" failed. open registry file failed :No such file or directory
ERROR: fail to unregister jrm with daemon manager.
ERROR: unregister daemons "WebServer" failed. open registry file failed :No such file or directory
ERROR: fail to unregister WebServer with daemon manager.
ERROR: /etc/init.d/dmgtd not found. Manual Stop of dmgtd.sol process required.
Second install:
INFO: Testing syslog: sending a msg to local0.debug...
INFO: waiting for 12 seconds for syslog to process a test message...
ERROR: unregister daemons "JRunProxyServer" failed. :Connection refused
ERROR:save failed Add failed, record already exists., Error 0
Argument "/opt/CSCOpx/objects/jrun/jsm-cw2000/properties/jsm.prope..." isn't numeric in chown at /opt/CSCOpx/conf/cmf/bin/jrunConfigure.pm line 1070, chunk 145.
Argument "/opt/CSCOpx/objects/jrun/jsm-cw2000/services/jse/propert..." isn't numeric in chown at /opt/CSCOpx/conf/cmf/bin/jrunConfigure.pm line 1070, chunk 145.
usage: chown [-fhR] owner[:group] file...
usage: chgrp [-fhR] group file ...
Daemon Management 3.5 starting. Log=(syslog) /var/adm/CSCOpx/log/dmgtd.log
I'm bogged down right here, no point in proceeding ahead.
"/etc/init.d/dmgtd: not found"
Is this the culprit?
This is all very bad, and most likely indicative of CSCsa34490. The bug notes contain the workaround.
Thanks! That's probably it.
