MAC address of device on port
What command or commands will give me the MAC address of the device that is plugged into a particular port on a switch?
Re: MAC address of device on port
Try this:
sh mac-address-table | include
IOS or CatOS?
OR
sho cam dynamic
SHOW MAC-ADD INT G2/1, for example, in IOS on gigabit port 2/1. Really helps us to help you if you can provide the OS.
You can also solicit this information from the device using SNMP from this structure:
.1.3.6.1.2.1.17.4.3
+--dot1dTpFdbEntry(1) detail
+-- -R-- String dot1dTpFdbAddress(1)
| Textual Convention: MacAddress
+-- -R-- Integer dot1dTpFdbPort(2)
+-- -R-- EnumVal dot1dTpFdbStatus(3)
| Values: other(1), invalid(2), learned(3), self(4), mgmt(5)
These will index back to ifIndex which you can use to get the port description from ifDescr. Both of these values come from the ifEntry table.
267
