management interface software for 6500's?
Is there such an application?
I'm currently using the Network assistant but it only support the descktop switches, not the core 6500's.
Thanks for the info.
Re: management interface software for 6500's?
CiscoWorks LAN Management Solution supports the 6500. You have CiscoView to display a graphical chassis view, Campus Manager to display the switch's topology, USer Tracking to collect end users connected to the switch, DFM to manage the switch's faults, and RME to do inventory, config, and software management.
where do you get this software?
Also, how do it communicate to the core 6500? Via telnet or ssh or http?
We have http and telnet disabled by default...
136
