Webcast-Catalyst9k
Managing routers with a changed prompt
we have a client that has changed the default prompt in some routers. I remember that in LMS 2.5 it was necessary to modify a file in the LMS server in order to indicate the CiscoWorks that some routers had another prompt.
Is it already necessary this file in LMS 3.1? If so, which is this file?
Many thanks.
1 ACCEPTED SOLUTION
Blue
Re: Managing routers with a changed prompt
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_resource_manager_essentials/4.2/user/guide/config.html
/opt/CSCOpx/objects/cmf/data/TacacsPrompts.ini
Add your custom prompts to the file, separated by commas. This example shows adding "TACACS User Name:" and "TACACS Password:" prompts respectively:
[TELNET]
USERNAME_PROMPT=Username:,username:,login:,TACACS User Name:
PASSWORD_PROMPT=Password:,password:,passwd:,TACACS Password:
1 REPLY
Blue
[TELNET]
144
