Many devices are partially successful in RME config management summary
Dear all,
Many devices are partially successful in RME config management summary.It report error "CM0012: Unable to create new version on archive $1 Action: Check if disk space is available and directory has required permissions" How can i do?
Thanks!
Re: Many devices are partially successful in RME config manageme
It's the known bug CSCsh69403 in RME4.0x which is fixed in 4.1. The Workaround for 4.0x is to delete the device in Common Services and re-add it again to Common Services and RME.
Looks like this is closer to DDTS CSCsh39475 which might actually be fixed in RME 4.0.6
Yes,
nevertheless the workaround is the same.
But we have so many devices,it is not been accepted that we delete them then re-add them.
Anyone have other suggestion?
Thanks!
111
