Marking DSCP traffic generated internally in a 3750.
I'd like to mark DSCP in hardware at the remote sites 3750 (12.2(44)SE1) switches instead of at the remote WAN router. It's working fine except for traffic that is generated in the 3750, like SNMP reply's and IP SLA responder traffic - traffic that is actually generated in the 3750. The 3750 will only let me apply a service policy to the inbound direction of a physical interface in a 3750. Any ideas?
1 ACCEPTED SOLUTION
Re: Marking DSCP traffic generated internally in a 3750.
This is the IP SLA configuration I have on a Catalyst 3550 to test VoIP:
ip sla 10
udp-jitter 192.168.255.250 32768 source-ip 192.168.255.254 source-port 32768 codec g711alaw
tos 184
The 'tos' setting sets the whole ToS byte, so in this case it sets DSCP EF (101110 + 00).
Andy
Randy,
The 3550,3560 & 3750 do not allow an outbound policy for marking layer2 CoS or Layer DSCP, just inbound per input cos-dscp or dscp-cos maps.
HTH>
With the 3750 you can configure DSCP for certain management traffic generated by the switch itself. By default some traffic is already marked with CS6. I looked into this a while ago:
ip telnet tos <0-FF>
ip ssh dscp <0-63>
snmp-server ip dscp <0-63> or
snmp-server ip precedence <0-7>
For IP SLA you can set the ToS on the 'server' and the responder will use the same ToS value.
You can also use a local policy to set IP Precedence for traffic generated by the 3750:
ip access-list extended NTP
permit udp any any eq ntp
route-map Set-DSCP-NTP
match ip address NTP
set ip precedence <0-7>
ip local policy route-map Set-DSCP-NTP
I have never tested the local policy stuff on a Catalyst 3750 however I have on a 'real' router and it worked on that. The other stuff works fine though.
Andy
That is a very helpful reply. Thank you.
Can you tell me how to set IP SLA ToS on the 'server'? I don't see that option in the CLI help.
ip sla 10
tos 184
Andy
This is working slick.
Thanks again.
Good, I am glad you found it useful. You can always rate useful posts you know..... :o)
Andy
1674
