Measuring the Point-to-Point Lease Line Bandwidth
Dear All,
Any tools that can use it for test the available bandwidth for the point-to-point lease line?
Re: Measuring the Point-to-Point Lease Line Bandwidth
If you want to have a check on the bandwidth utilization on your leased line you can very well check using show interface serial x/x on which your link is connected.
If you want to have records on the periodic bandwidth usage you can check these links out..
http://www.mrtg.org
http://people.ee.ethz.ch/~oetiker/webtools/mrtg/mrtg-nt-guide.html
http://www.cacti.net
http://www.slac.stanford.edu/xorg/nmtf/nmtf-tools.html
http://www.solarwinds.net/Tools/Engineer/index.htm
regds
Silver
Hi ,
you can check the bandwidth using what's up gold freeware.It gives detailed info about the bandwidth utilization.
Dear smothuku,
any url that can download the freeware that you mention?
Thank you.
Silver
U can download freeware using the following link.
http://www.uksuperweb.co.uk/whatsup.html.
You can monitor the status each and every device in your network and bandwidth utilization of each device.
satish
878
