03-07-2006 01:45 AM
Do anyone know the MIB for SNMP collection CPU usage for Switch 2970 (WS-C2970G-24TS-E)? Also need the MIB for memory usage.
Solved! Go to Solution.
03-07-2006 04:56 AM
Try these:
CPU: 1.3.6.1.4.1.9.9.109.1.1.1.1.6 (The overall CPU busy percentage in the last 5 second
period.)
For the memory OIDs, open up the links I gave you, then click on the appropriate variables which will open up a window with the required OIDs.
Pls rememeber to rate posts.
Paresh
03-07-2006 02:33 AM
Any ideas? May be I have to download them?
03-07-2006 03:18 AM
Have you tried the CISCO-PROCESS-MIB ?
Here's a link to it:
You can get stats on memory usage from the CISCO-MEMORY-POOL-MIB:
Both are supposed to be supported on the 2970G.
Hope that helps - pls rate the post if it does.
Paresh
03-07-2006 04:34 AM
But I do not find the specified OID. I need to collect via SNMP the CPU and memory load. For that I use MRTG, in mrtg config file I have to specify the OID for CPU usage and memory usage.
So, I need the OID for CPU and memory. On these links there are no OIDs.
An OID is composed from numbers, something like 1.3.6.1.4.1.9.4.1.23.0. So I need these numbers for cpu and memory.
Thanks for helping me.
03-07-2006 04:56 AM
Try these:
period.)
Paresh
