Community Member
MIB integration
Can someone tell me if it possible to add the Call Manager Mibs in the What's Up Gold version 11???how can I do that?
Bronze
Re: MIB integration
Yes it is possible. You have to do follow the steps: Enabling the SNMP Agent than Verifying Enabling of the SNMP Agent (optional) and also you have to Enabling Cisco CME Network-Management Notifications and Trap. For more information please click following URL:http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_mib_quick_reference09186a00805567ba.html#wp1065169
Re: MIB integration
here are some docs that gives good information on this issue; always keep mib dependencies in mind when adding mibs to WUP
be careful with the drag and drop operation described here as there is no validation done before adding the mib (validation on dependencies on other mibs, format errors,etc)
http://support.ipswitch.com/kb/WP-20050429-DM01.htm
in this doc you have a link to a mib validator
http://support.ipswitch.com/kb/WG-20011109-DM01.htm
but I think you can still do it with "mibextra" as described here:
187
