11-02-2005 05:49 AM
Is there a software download on the Cisco website for the Mini RMON application?
It seems I must reload the application.
Getting error....Mini RMON device package has not been installed properly or it has been uninstalled.
Any suggestions?
Thank you.
11-02-2005 05:54 AM
Is this related to LMS 2.5 in any way?
11-03-2005 06:46 AM
Yes.
11-03-2005 06:52 AM
The mini RMON for LMS 2.5 is part of CiscoView 6.1.1
It is available for downoad at:
11-03-2005 07:01 AM
I have installed this and all the service packs for Common Svcs and CiscoView 6.1.1.
If I try to reinstall the cd, will it damage the application files and all the service packs that are installed?
Would it be safe to re-install? I am running it on Solaris 2.8 on a SUN 450 enterprise server.
11-03-2005 07:04 AM
If you try to re-install from CD, you will have to re-install all the service packs as well.
Where / when do you get the error message about mini RMON?
11-03-2005 07:12 AM
I get the error either if I use the application thru Chassis View or try to use Mini RMON straight from CiscoView module.
The Mini RMON application gives me an overview page and when I enter in either an ip address or device name that I have verified that is in the DCR, then I get the error.
11-03-2005 07:29 AM
Then maybe a re-install of CV 6.1.1 is all you would need.
11-03-2005 08:08 AM
Should I open a TAC case to see how to do that?
I have checked the cisco downloads and do not see the CiscoView application only device packages and patches. The CD I received the files does not just have a directory for the CiscoView app that I can see.
11-03-2005 08:19 AM
CiscoView 6.1.1 is available at:
