02-22-2007 10:33 AM
I'm trying to use mini-rmon on our core 4507R, and when I select the port I wish to monitor and press enable, I get the following message:
_________________________________________
Message
Failed to Enable Statistics Collection !
Cause
Could be due to one of the following reasons
1.) Lack of access to the host
2.) Invalid SNMP credentials
3.) Device is busy in handling SNMP queries.
4.) This feature might not be supported by the SNMP Agent.
I ran a device credential verification job against the switch, and all snmpv2, as well as the telnet and enable tests passed. Also, I can change the 'location' and 'contact' information on the device from the setup page of CiscoView, so I know the credentials are good.
Is there something I am missing? The IOS version on the switch is 12.2(25)EWA.
Action
Verify access, SNMP credentials or increasing timeout value through the preferences option. Also, please check the User Guide for Release Notes
02-28-2007 12:00 PM
Start a sniffer trace on the LMS server filtering on UDP port 161 traffic to this switch. Then reproduce the problem. The resulting trace should indicate what error the switch is sending to the SNMP SET.
03-01-2007 06:53 AM
Thanks, I'll fire the sniffer up and have a look. Before that though, I noticed that when I do a show run on the switch, there is no engineID under the snmp section. It looks as follows:
logging x.x.x.x
snmp-server community xxxxxx RO
snmp-server community xxxxxx RW
snmp-server location ServerRoom
snmp-server contact xxxxxxx
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps tty
snmp-server enable traps vtp
snmp-server enable traps vlancreate
snmp-server enable traps vlandelete
snmp-server enable traps stpx
snmp-server enable traps rf
snmp-server enable traps port-security
snmp-server enable traps config
snmp-server enable traps entity
snmp-server enable traps cpu threshold
snmp-server enable traps copy-config
snmp-server enable traps fru-ctrl
snmp-server enable traps flash insertion removal
snmp-server enable traps syslog
snmp-server enable traps bridge
snmp-server enable traps envmon
snmp-server enable traps hsrp
snmp-server enable traps bgp
snmp-server enable traps ospf state-change
snmp-server enable traps ospf errors
snmp-server enable traps ospf retransmit
snmp-server enable traps ospf lsa
snmp-server enable traps ospf cisco-specific state-change
snmp-server enable traps ospf cisco-specific errors
snmp-server enable traps ospf cisco-specific retransmit
snmp-server enable traps ospf cisco-specific lsa
snmp-server enable traps pim neighbor-change rp-mapping-change invalid-pim-message
snmp-server enable traps ipmulticast
snmp-server enable traps msdp
snmp-server enable traps rtr
snmp-server enable traps vlan-membership
Shouldn't there be an engineID by default, and could this be causing the problem?
03-01-2007 09:03 AM
It depends on the version of IOS. If the engineID was truly deleted, no SNMP operations would work on the device. You said earlier that you are able to perform other GETs and SETs. You can do a show snmp engine to see the engineID.
03-20-2007 08:09 AM
Just thought I would send an update in case anyone had the same problem. It turns out that the problem is being caused by a bug in the IOS (12.2(25)). Here is the message from TAC:
"I have received an update from the CiscoView developer and it seems that the problem is on the IOS side. It seems that you are hitting a bug that does not allow miniRMON to create entries in the SNMP tables required, which causes your error messages."
He asked me to tell you to upgrade your 4507 to IOS 12.2(31)SGA or
higher version and try the miniRMON again. Please let me know if this
helps to fix the problem."
03-20-2007 09:24 AM
What was the bug ID you received?
03-20-2007 09:26 AM
TAC did not give me one. Maybe it's a new one?
03-20-2007 11:02 AM
That's why I asked. I could not find one. TAC definitely should have given you an ID, new bug or not. Since they asked you to upgrade, that would make me think it was a known, resolved bug. What is the SR number?
03-20-2007 11:04 AM
SR605472477
03-20-2007 11:35 AM
The bug you are hitting is CSCef19969. It states that one is unable to create entries in the RMON etherStatsTable via SNMP. You will need to upgrade to 12.2(31)SG or later to get the fix for this bug.
