Missing Applications in LMS 3.01
Hello all:
I have a LMS 3.0.1 running on a Solaris 10 Sun X2100. When i performed the installation i miss to install Both DFM and IPM since there were another tool which were going to do this application job.
Now, i have to install the tools but i'm expecting troubles following the instructions to install.
this is the instructions given by white papers:
Step 1 Go to NMSROOT/setup and look for the .info files for the LMS applications that are installed already.
Step 2 Modify the .info files and set the value of PATCHVER in these files to their original value of 0.
Step 3 Install the missing LMS 3.0 applications and wait for the installation to complete.
I have finded the files in /OPT/CSCOpx/setup and set the values to 0 ( as suggested) but when i try to install the applications this erros is returned:
ERROR: Install CiscoView 6.1.2 before installing LMS3.0 Applications..
Finished: Wed Dec 10 17:44:46 CET 2008
===============- Software Installation Tool Completed -==============
===================- Possible Warnings/Errors Encountered -===================
Do i have just to check some of the files to restore de PATCHVER value to 0?
How can i overlap the error returned?
Thank you in advance
@ngel!
1 REPLY
Re: Missing Applications in LMS 3.01
By the way :)
i have Ciscoview installed , so , i really don't understand the error.
I'm going to reinstalate it now ( CiscoView ) but i have not much hope to fix with it
96
