Community Member
Missing detailed device view in DFM
Any idea why i cant see detailed device view in DFM. Some devices are fine but some
devices detailed device view elements are not present.(under system and InterfaceStatus)
Also if device detailed device view is OK but trunk ports may not be managed state.(i thought that trunk ports are managed by default) I use snmpv3 and this is fresh install of LMS 2.6 with new updates.
I can do snmpwalk(v3) from device center E.g. to device which detailed device view is short.
Juha
Re: Missing detailed device view in DFM
It doesn't look like this device was properly managed. It could be that your SNMPv3 views are wrong. Check the config to make sure you're granting access for your v3 user to read the entire MIB tree. You might also try deleting the device from DFM, then re-adding it, and running a sniffer trace during the initial discovery to see if there are any SNMP errors.
Community Member
After reboot dfm starts manage all devices OK
Juha
112
