06-21-2007 07:14 AM
Hello, I found missing textual OID in
CISCO-PRODUCTS-MIB .1.3.6.1.4.1.9.1.634 for Catalyst 3650 model number WS-C3560-48TS
Where is the right place for bug report? I tried to send email to cm-snmp@cisco.com which is defined in the MIB file, but this mailbox in invalid.
Is this MIB regulary revised before new product is introduced into the public market?
Solved! Go to Solution.
06-21-2007 07:26 AM
Products are sometimes released before a new revision of this MIB.
You can edit the file yourself and add this switch for the time being as a workaround.
You can also open a TAC SR to report the problem.
06-21-2007 07:26 AM
