08-31-2006 07:15 AM
I am trying to figure out how to monitor total active calls. I have browsed through MIB and manually tried OID's with no luck. While browsing the MIB I can see different active call tables being populated, but I cannot monitor the table or figure out how. Please help. This is a c2851 with 12.3(14)T6.
08-31-2006 07:35 AM
Try CISCO-POP-MGMT-MIB
cpmDS0CallType
cpmL2Encapsulation
cpmCallCount
cpmTimeInUse
cpmAssociatedInterface
cpmDS1TotalCalls
cpmDS1TotalTimeInUse
cpmDS1TotalDigitalCalls
cpmActiveCallSummaryTable
cpmCallHistorySummaryTable
cpmDS1ActiveDS0s
cpmActiveDS0sHighWaterMark
cpmDS1ActiveDS0sHighWaterMark
08-31-2006 07:56 AM
The CISCO-POP-MGMT mib is most likely not supported on this hardware. The CISCO-POP-MGMT-MIB was designed/intended for dial platform such as AS5xxx. It will have some support for the 26xx/36xx platforms as these
platforms have dial functions as well.
You may get some good info from:
CISCO-VOICE-DIAL-CONTROL-MIB: "cvVoIPCallActiveTable"
"1.3.6.1.4.1.9.9.63.1.3.2"
DIAL-CONTROL-MIB: "callActiveTable"
"1.3.6.1.2.1.10.21.1.3.1"
DIAL-CONTROL-MIB: "callActiveCallState"
"1.3.6.1.2.1.10.21.1.3.1.1.9"
Also for Historical data, the following looks promising :
CISCO-VOICE-DIAL-CONTROL-MIB: "cvCallHistoryTable"
"1.3.6.1.4.1.9.9.63.1.4.1"
Also, to get something similar to the information of the command "sh call
voice active brief" you could do something like what I have below: (have
provided the MIB info next to it, for easier understanding)
H323 leg
pid:
callActivePeerId.291909790.1 = INTEGER: 200
callActiveCallOrigin.291909790.1 = INTEGER: answer(2)
callActivePeerAddress.291909790.1 = STRING: 205
callActiveCallState.291909790.1 = INTEGER: active(4)
tx:
callActiveTransmitPackets.291909790.1 = Gauge32: 85692
callActiveTransmitBytes.291909790.1 = Gauge32: 13710323
rx:
callActiveReceivePackets.291909790.1 = Gauge32: 85621
callActiveReceiveBytes.291909790.1 = Gauge32: 13699680
For the Telephony leg
pid:1
callActivePeerId.291909815.1 = INTEGER: 1
Originate
callActiveCallOrigin.291909815.1 = INTEGER: originate(1)
93928027
callActivePeerAddress.291909815.1 = STRING: 93928027
active
callActiveCallState.291909815.1 = INTEGER: active(4)
tx:
callActiveTransmitPackets.291909815.1 = Gauge32: 85619
callActiveTransmitBytes.291909815.1 = Gauge32: 13699360
rx:
callActiveReceivePackets.291909815.1 = Gauge32: 85695
callActiveReceiveBytes.291909815.1 = Gauge32: 13710963
08-31-2006 12:14 PM
thanks davistan for the correct info. you are a true asset to NetPro. Thanks for your assistance.
08-31-2006 01:05 PM
No problem! The MIBs Jorge mentioned above usally work, but is very platform dependent. I have had a few issues with people looking for this MIB support on the ISR's.
08-03-2007 08:01 AM
I am trying to do the same thing where I want to find out the number of active calls going on my voice router, which has two T1 PRI's plugged into it.
I have looked everywhere on the internet and walked the MIB of the device and I cannot find the OID for the current active calls. The information above didnt seem to help me. Maybe I didnt under stand the output but I was hoping for a single OID that would return "xx" for active calls.
I have a 2811 with 12.4(16).
