05-30-2007 07:25 AM
Hello I have a problem with qpm 4.0.
I have tried to monitor a class based qos policy on a cisco 1800 and I can monitor it but if I tried to monitor same policy on a catalyst 3750 or on a catalyst 3560 i cannot because qpm display that there aren't monitorable policies(see attachment).
I think I cannot monitor qos policies on 3560 and 3750, correct?
Solved! Go to Solution.
05-30-2007 11:43 AM
Monitoring is only supported on devices that support the CISCO-CLASS-BASED-QOS-MIB and CISCO-CAR-MIB. Unfortunately, the desktop switches (e.g. 3750, 3560) do not use this MIB. They use the CISCO-PORT-QOS-MIB, and thus cannot be monitored.
05-30-2007 11:43 AM
05-30-2007 11:05 PM
Thank you for your response.
Cisco is the best
