Community Member
Monitor Vlan Bandwidth/ Usage
We use catalyst 6500's and 3500's. I am taking over control of this network and want to know if there are users that should be moved to a different vlans. I am mainly concerned with broadcast domains and overall bandwidth.
Todd Kroeker
Highlighted
Re: Monitor Vlan Bandwidth/ Usage
Do you have a NAM in the 6500 that you could use for monitoring traffic?
Community Member
No I do not.
Bronze
Me personally, I would install cacti (http://www.cacti.net) and then graph every single interface/port.
Then go from there.
Community Member
Thanks. i'll take a look
Todd
Todd, you may also try PRTG traffic grapher,
they provide up to three free sensors in
their software whereby you can monitor real time traffic on a physical interface. For more than three interfaces then you have to purchase software.
http://www.paessler.com/prtg
Jorge
2141
