Monitored Phones is zero on 1040 after upg to CUSM 2.2
The two 1040 sensors were running and I could see MOS reports on CUSM 2.1.
After the upgrade to CUOM 2.2/CUSM 2.2 I can see the CUCM based CVTQ reports but not the sensor based reports. The two sensors show zero Monitored Phones. From the sensors web page I can see on the Diagnostics link that the sensors are indeed analysing streams and sending data. The sensor image file was changed to the SvcMonAB2_102.img as required by the install procedures. Both sensors are registered with the CUSM 2.2.
The syslog.log only shows data after setting Logging debug level an shows sensor data:
19-Aug-2009|17:09:12.181|INFO |syslog|Thread-311|<14>Aug 19 17:07:00 PJCCRPB-P01 SvcMonA_200908191707[001120FFFF72]: %%<A=0,B=a.64.9.88,C=a.64.60.3c,D=4,E=44,F=N,G=0,H=1,I=0.0,J=0.0,K=59977,L=0,M=0,N=0,O=44,P=445974920,Q=19286,R=32506,S=2><A=0,B=a.64.60.21,C=a.64.9.89,D=4,E=44,F=N,G=0,H=0,I=0.0,J=0.0,K=59979,L=0,M=0,N=184,O=44,P=2490249315,Q=25858,R=17856,S=0><A=0,B=a.64.9.89,C=a.64.60.21,D=4,E=44,F=N,G=0,H=1,I=0.0,J=0.0,K=59980,L=0,M=0,N=0,O=44,P=139200905,Q=17856,R=25858,S=3><A=0,B=a.64.60.3c,C=a.64.9.88,D=4,E=44,F=N,G=0,H=0,I=0.0,J=0.0,K=59979,L=0,M=0,N=184,O=44,P=402553528,Q=32506,R=19286,S=1>%%
19-Aug-2009|17:09:12.197|INFO |syslog|Thread-311|<14>Aug 19 17:07:00 PJCCRPB-P02 SvcMonA_200908191707[001120FFE596]: %%<A=0,B=a.64.7c.20,C=a.64.7c.22,D=4,E=44,F=N,G=0,H=0,I=0.0,J=0.0,K=12158,L=0,M=0,N=184,O=44,P=3650118751,Q=25212,R=18416,S=0><A=0,B=a.64.7c.22,C=a.64.7c.20,D=4,E=44,F=N,G=0,H=0,I=0.0,J=0.0,K=12138,L=0,M=0,N=184,O=44,P=3637912869,Q=18416,R=25212,S=0><A=0,B=a.64.9.8d,C=a.64.7c.2a,D=4,E=44,F=N,G=0,H=0,I=0.0,J=0.0,K=13214,L=0,M=0,N=0,O=44,P=14947,Q=29690,R=30956,S=0><A=0,B=a.64.7c.16,C=a.64.5.46,D=2,E=44,F=N,G=0,H=0,I=0.0,J=0.0,K=59959,L=0,M=0,N=160,O=44,P=15130,Q=3468,R=60116,S=1><A=0,B=a.64.5.46,C=a.64.7c.16,D=2,E=44,F=N,G=0,H=0,I=0.0,J=0.0,K=59958,L=0,M=0,N=160,O=44,P=855234534,Q=60116,R=3468,S=2>%%
So the sensor are sending the data.
I have found errors on the monitor.log:
14-Aug-2009|12:25:05.447|ERROR|Monitor|main|QOVRDbMonitor loaded from : C:/Program Files/CSCOpx/SimpleLog/sl_monitor.conf
14-Aug-2009|16:43:41.873|ERROR|Monitor|main|QOVRDbMonitor loaded from : C:/Program Files/CSCOpx/SimpleLog/sl_monitor.conf
19-Aug-2009|02:11:41.381|ERROR|Monitor|Thread-1|Occurred during maintenance: java.io.IOException: Cannot run program "cmd": CreateProcess error=1450, Insufficient system resources exist to complete the requested service
19-Aug-2009|02:16:41.392|ERROR|Monitor|Thread-1|Occurred during maintenance: java.io.IOException: Cannot run program "cmd": CreateProcess error=1450, Insufficient system resources exist to complete the requested service
19-Aug-2009|16:27:50.961|ERROR|Monitor|main|QOVRDbMonitor loaded from : C:/Program Files/CSCOpx/SimpleLog/sl_monitor.conf
Any help is appreciated
  • Network Management
265
