11-07-2007 07:38 PM
Is there a monitoring system to monitor the type of traffic and ports for some of the sites inside a MPLS cloud.
Rajesh
11-08-2007 12:14 AM
I think that the easiest way is to use a netflow. You can also use a static probe, etc, but the netflow is almost supported on Cisco devices.
Jan Nejman
Caligare, Co.
http://www.caligare.com/
