Monitoring LAN to LAN Tunnels
I have a number of 3800 ISR with LAN to LAN IPSEC VPNS.
One One Gig port I have 18 VPN's my network monitor on alerts if the physical interface drops. I would like to monitor each tunnel and alert if it fails. I have tried a few different OID.
Can any one recommend what OID to monitor to alert a tunnel down.
Silver
Re: Monitoring LAN to LAN Tunnels
To monitor LAN to LAN Ipsec VPN tunnel
User these commands on routers.
Router# show crypto ipsec sa
Router# show crypto isakmp sa.
You can view the IPsec and IKE statistics when you select Monitoring > Statistics > IPSec on the VPN Concentrators.
For further information click this link
http://www.cisco.com/en/US/products/hw/vpndevc/ps2284/products_configuration_example09186a00801f0f0c.shtml
Thanks for the reply, but I am really looking for snmo monitoring rather than CLI.
I have tried watching phase one but is the tunnel state is UP-NO-IKE it alarms down.
If I watch phase two tunnel numbers, these change and the tunnel alarms down.
Right now I am alarming on the absence of any tunnel.
I am just wondering if there is a better way
140
