Community Member
Monitoring Object tracking with SNMP
I need to find a way to monitor via SNMP or Syslog how to monitor the object tracked routes on a ASA 5505.
When my connection fails over from cable to dsl or vice versa I'd like to recieve a alarm or email via Cisco Works or Whatsupgold.
Below is part of the configuration
track 3 rtr 3 reachability
track 4 rtr 4 reachability
sla monitor 3
type echo protocol ipIcmpEcho 4.2.2.2 interface backup
frequency 15
sla monitor schedule 3 life forever start-time now
sla monitor 4
type echo protocol ipIcmpEcho 4.2.2.3 interface outside
frequency 15
sla monitor schedule 4 life forever start-time now
Blue
Re: Monitoring Object tracking with SNMP
It seems ASA's IP SLA configs are not as far along as that of IOS, in terms of alerting.
I suppose you could either roll your own and write a "robot" script to log into each ASA to parse the "sla monitor" output accordingly, or configure the IPM piece of CiscoWorks LMS to do it for you: IPM - Collector Mgmt - Operations - Generate Action Event - Event Type: SNMP Trap.
The robot script would have to be the way as the ASA does not support the CISCO-RTTMON-MIB, therefore IPM will not be able to manage them.
Blue
Would you know when CISCO-RTTMON-MIB support would be added, or the ASA IP SLA capabilities be expanded to match the IOS?
No idea. This is the first time I heard about IP SLA support in the ASA. I haven't seen any ASA IP SLA SRs in the NMS TAC, and I'm not seeing any enhancement requests pending.
Community Member
I am working with Cisco on a way for the ASA to email these track changes. I really would like to find a way to snmp it - any other ideas?
There is no MIB support in the ASA to support tracking. There is just no way to do it with SNMP.
1879
