Community Member
Monitoring optical level cisco nexus 7010, 5548.
Good day!
Please help me find oid for monitoring optical levels by snmp.
Hi ,
Have you tried to snmpwalk the entSensorValueTable
(.1.3.6.1.4.1.9.9.91.1.1.1) from the CISCO-ENTITY-SENSOR-MIB
It¹s indexed by entPhysicalIndex, so you¹ll need to snmpwalk the
entPhysicalDescr (.1.3.6.1.2.1.47.1.1.1.1.2) to map the index in the above
table to a name/entity indexed by the same # here.
what is the equivalent CLI for the same ?
Thanks-
Afroz
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
Hi Igor
Just check if you are looking for this.
https://supportforums.cisco.com/docs/DOC-36517
If yes this is not supported on Nexus.
Mahabir
421
