monitoring power outages
Is there anyway to gather info on power outages, or internal failures from the switch cli? If no, how can I monitor this kind of activity? Any help is greatly appreciated thx.
Red
Re: monitoring power outages
It all depends on the switch type
Try one of the following commands:
show env ?
show power ?
Thank you for replying...this was helpful, but I was looking more for a way to capture a power failure into a log file somehow...is this at all possible...thx in advance.
By default these messages go to the log file. You could also configure the devices to log messages to a syslog server.
Thanks I will look into this.
266
