Monitoring PRI using Embedded Event Manager
kevinhobson2000
I am trying to use Embedded Event Manager to flag  when calls on a pri get above
28 but its not working.  I found an OID which shows number of calls currently on
the B Channels of a pri.  I dropped the threshold to two just to check it was
functioning correctly.  Config below:
event manager applet bchan-mon
event snmp oid 1.3.6.1.4.1.9.10.19.1.1.11 get-type exact entry-op gt entry-val
2 poll-interval 60
action exceeded syslog priority critical msg "All Chanels in Use"
I have done a debug and it says the OID is not found even though if i do a show
snmp mib i see the OID.  Output below:
Feb  9 08:35:58.097: fh_process_async: re=445EF694, timer_type=POLL
Feb  9 08:35:58.097: snmp_entry_value_check: OID unavailable, value check
skipped
Feb  9 08:35:58.097: snmp_entry_value_check:Returning FALSE
Feb  9 08:35:58.097: fh_process_async: update_t=0cron_tick: num_matches 0
Has anyone successfullly used EEM to do this?
Any help appreciated.
Kev
Joe Clarke
First, this is not an object instance.  You need to add a .0 to the end of this OID.  Next, this object may not return what you want.  Have you tried performing an SNMP Walk or Get on this object to see if it works?  What version of IOS is your device running?  What kind of device?
Hi Joe,
I get this from an snmp walk:
rh019654@c_nnm_u > snmpwalk lr2196 1.3.6.1.4.1.9.10.19.1.1.11
cisco.ciscoExperiment.19.1.1.11.0 : Unsigned32: 0
The device is a cisco 2851 and the IOS is C2800NM-SPSERVICESK9-M 12.4(18e).
If i run a debug now after adding the 0 i dont get a OID error not found anymore but its still not flagging the message in the log when the amount of calls go above 2.  See below:
Feb 10 09:43:17.774: fh_process_async: re=463448F0, timer_type=POLL
Feb 10 09:43:17.774: snmp_value_uint_compare:op1=0 op2=2 ret=FALSE
Feb 10 09:43:17.774: snmp_entry_value_check:Returning FALSE
Feb 10 09:43:17.774: fh_process_async: update_t=0
Kev
Hi i got this working by using a different OID which is 1.3.6.1.4.1.9.10.19.1.1.4.0 .
Cheers
Kev
