Monitoring Services
Can LMS monitor the services like smtp and http? If can, where can I configure it in LMS? Also, if this service fails, can i configure it to send email to notify us? Thanks in advanced!
regards,
reymon
Re: Monitoring Services
Ciscoworks is not meant to do this. It's only meant to manage cisco devices
However IPM allows for monitoring of http and a tcp connect on port 25 could be used to check a SMTP server.
IPM can send a trap if a threshold is passed, but not a mail.
Cheers,
Michel
Hi michel!
Thanks for your response! Monitoring http and tcp connect on port 25 is showing only latency and availability graph. How can lms trigger me if i got problem on this 2 services?
Cheers,
reymon
There are thresholds and actions you can set. It's to long ago to be more precise I'm afraid.
I recall I looked for "User-Defined Operation" and threshold in helps files of IPM.
It's not as flexible as with the automated actions in RME though.
Cheers,
Michel
109
