Webcast-Catalyst9k
monitoring VPN3000 from CWLMS - 2.1
Trying to configure a VPN300 device for monitoring from CWLMS-2.1. The VPN3000 has SNMP server configuration page, where one can configure the community string. The problem is, it does not say whether it's the read or read/write community string and anny attempts to add this device to my CWLMS have been unsuccessfull because of the wrong community string. Has anybody managed to successfully do this?
Thanks.
Red
Re: monitoring VPN3000 from CWLMS - 2.1
VPN 3000 has Read Only SNMP access. There is no RW string.
Thanks for your response. I must be doing something wrong as I can't even send an SNMP getnext request from the management station to the device. The ping and traceroute work OK. The SNMP is enabled on the VPN 3000 box and the port 161 is opened.The Community string on the VPN 3000 box is identical to the one I am using for sending an SNMP getnext request. Is there a seting on the VPN 3000 I am missing?
Thanks again.
115
