MPLS L2 VPN on 2 trunk Port
I have a 7606 and Me3400 switch both are connected on fiber. SFP on ME and Gbics on Cisco 7606 router. ring protection.
20 VLAns are allowed in this trunk. Can I initiate L2 VPN from VLANs ? as now there are 2 physical ports in use. Normally xconnect command works on single interface or sub interface.
1 REPLY
Silver
Re: MPLS L2 VPN on 2 trunk Port
To create Layer 2 VPN connections between two ports on the same router, use the connect command in global configuration mode. To remove such connections, use the no form of this command.
connect connection-name interface [dlci | pvc | pvp] interface [dlci | pvc | pvp] [interworking ip | ethernet]
Refer the below URL for more information:
http://www.cisco.com/en/US/docs/ios/12_0s/feature/guide/fslocal.html#wp1170945
138
