MRTG - Top n Only!
Hi, group.
Can I utilize MRTG to graph Top n only out of thousands of switch ports? thanks.
Leo
Re: MRTG - Top n Only!
You can graph vlans or ports of your choice, you just need to edit the mrtg.conf file and specify there what interfaces you want to monitor.
I am ok and able to pull thousands of switch ports' utilization, but I do not require MRTG to present every single of them, I do hope somehow MRTG could just pick Top n dynamically to feed them into a .cfg file, thus, I would have a real-time snapshot of those Top n switch ports' utilization in our network, which i believe would be very useful. so, is it possible? Leo
absolutly. You need to edit the cfg file I mentionned earlier.
ok, figure it out by myself, it does take a while.
short answer, routers2.cgi http://www.steveshipway.org/software/
Leo
262
