Silver
MS Active Directory module in LMS 3.0
I want authentication of LMS 3.0 via my Active directory Server. As per LMS 3.0 installation guide, I did but not successfull. I also not found enough material on this topic. Will I integrate it through Cisco ACS?
Re: MS Active Directory module in LMS 3.0
Yes, you can use the TACACS+ module to authentication to an ACS server which is using an AD database on the backend.
Silver
Thanks Clarke, what about if I used Non-ACS MS Active directory module of LMS 3.0? I try to use but it not function properly.
What error do you get using it? How have you configured it?
Silver
Dear Clark; please find the configuration I did on LMS common services;
Authentication - Non-ACS (MS Active Directory)
Server: ldap://ldap.companyname.com
userroot: cn=%user%, dc=servername, dc=companyname, dc=com.
prefix: cn=
login fallback option= true (only for Admin user)
I still not authenticate LMS through active directory. LMS give me access via fallback option (meand via admin user).
165
