MSFC with more IP addresses is seen as multiple devices in RME
The customer has problem with MSFC in LMS 2.5.1. On the MSFC is a configuration where are interfaces for VLANs with IP addresses. This MSFC is seen as three standalone devices in DCR. In the device selector is this device three times (with different IP addresses). Is this the normal behavior of LMS?? How I prevent the adding of this device with multiple IP addresses as more devices? Thank you.
1 REPLY
Re: MSFC with more IP addresses is seen as multiple devices in R
This looks like bug CSCse38513 and is actually caused by DFM.
When the switch's Sc0 was discovered, it led to the discovery of the MSFC. DFM placed the switch's address, as well as MSFC's Loopback0 address, in the "Known" state.
This should be fixed as part of DFM 2.0.6
DFM 2.0.6 is part of the LMS 2.6 Updates package, which you can download
and install by logging in to Cisco.com and pointing your browser to:
http://www.cisco.com/kobayashi/sw-center/cw2000/lan-planner.shtml
104
