N-Hop as Remote Portlet ?
Maybe I am missing something, but isn't the N-Hop View available as a remote portlet in a LMS 3.0 Multi-Server environment ?
1 ACCEPTED SOLUTION
Silver
Re: N-Hop as Remote Portlet ?
Exactly correct. N-hop is only accessable on the servers where Campus is installed, not the DCR master.
Silver
Ahh its an undocument feature! It threw me for a loop too.
What you need to do is log directly into the server which has campus installed on it and then add the potelet to that public space.
Whats strange is that it appears that the CW assistant workflow calls and displays it remotely from the Master from slaves corretly, but the Iframe can't touch it when you try and add it on the Master public space.
On the slave Campus Manager Server I can add this portlet in the public view, but if I login into the master server this portlet is not accessible.
Silver
92
