Community Member
N5K LMS 4.0 Credential issue
I need help with configuring our N5K switches on LMS.
As you can see from the below detail that I'm getting an error with SSH and is not even trying the Enable SSH pw.
Failed Devices
Showing 1-2 of 2 records
Device Name Read
Community
Read Write
Community
SSH Enable
by SSH
1.n5k-cr2OkOkIncorrectDid Not Try
2.n5k-cr1OkOkIncorrectDid Not Try
Looking at the configuratin of it I saw the below command:
username (Output Amended) password 5 (Some Password)  role network-operator
snmp-server user (Output Amended) network-operator auth md5 (Password) priv (Password) local
Is it the snmp-server user passwords that need to match with the Credential Sets in LMS?
Many thanks,
H
Hi ,
Are you using TACACS to device authentocation ?
Are there any Custom prompts configure on the device like :
login as:
Password:
If yes then open the TACACSPROMPT.ini file (NMSROOT/CSCOpx/objects/cmf/data )
check the device user prompts. Is it like
Username:
Password:
or something else. If it some thing else update the tacacsprompt.ini file
with respective prompt. This could be one of the reason for failure.
I hope this will help
Thanks-
Afroz
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
Community Member
We are not using TACACS.
Once I put the device IP address on Putty I get a prompt asking to login as, and then password.
Once I enter the detail I get to the # prompt.
many thanks,
H
Hi Haider
In the TACACSPROMPT.in  file .. add the below prompt or the way it appers on your device (case sensitive ):
login as:
Password:
then run the CDA job.
Thanks-
Afroz
Community Member
Hi Afroz,
The Tacacsprompt file has the following entries:
[TELNET]
USERNAME_PROMPT=
PASSWORD_PROMPT=
Should I change it to:
[SSH]
login as:
Password:
Also, what effects will this have on all the other non NexOS devices?
Many thanks,
Haidar
Hi Haider,
No need to change that ..It should be :
[TELNET]
USERNAME_PROMPT=login as:
PASSWORD_PROMPT=Password:
you can add many prompts with the sepration of , (Commma) character.
Community Member
I've just made the changes. I'm still confused because we're using SSH and not telnet. Also, when I configure the device credentials, what should I put? And, what about the snmp user server credentials?
These credentials are different than the username pw credentials!
Apologies for asking so many questions, but I would like to understand what changes I'm making and not only to get it working.
many thanks,
H
In TACACSPrompt.ini file it say's TELNET but it applies to SSH as well.
under >Primary Credential  >> you need to put user user name and password that you used to login to the device ( telnet\ssh)
check the below link:
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/4.0/user/guide/getting_started/managdevicegrps.html#wp1055262
Is the CDA job still faling after the changes in the file ?
if yes then : run the CmdsvcTest.pl
Syntax: CmdsvcTest.pl [ip] [port] [telnet|ssh] [ios|catos|nam][username] [login pass]
[enable pass] [telnet_timeout] [command1]  ...";
Example:
opt/CSCOpx/MDC/tomcat/webapps/rme/WEB-INF/debugtools>/opt/CSCOpx/bin/perl CmdsvcTest.pl
 22 ssh ios
 10 "show run-config" > output.txt
(this will redirect the output to 'output.txt', share the rsults with me)
NOTE for Nexus you may need to use SS instead of IOS in the above command
Community Member
Even if we're not using TACACS to authenticate?!
No, if you are not using TACACS then TACACSPROMPT.ini will not play any role.
Community Member
But I did say in my reply above that we're not using TACACS.
Any other suggestions then please to fix the issue if u don't mind?
Many thanks,
H
share the cmdsvctest.pl output to look into the issue.
Thanks-
361
