Bronze
NAM-2 questions
Hi there,
I have a few questions about the NAM-2 module for the 6500's. I just received a used NAM-2 from a department that was retiring some equipment and I'm having trouble getting it to work in my lab. I have a SUP720-3B running IOS 12.2(33)SXI2. When I insert the NAM-2, nothing happens, and the module reports that it has failed the SCP download. I was able to get it to boot off the maintenance partition and I pulled this information:
6506E-1#sh mod 5
Mod Ports Card Type Model Serial No.
5 8 Network Analysis Module (MP) WS-SVC-NAM-2 SAD074005P8
Mod MAC addresses Hw Fw Sw Status
5 0003.feac.fc2c to 0003.feac.fc33 2.0 7.2(1) 1.1(1)m Ok
Mod Online Diag Status
5 Pass
Will I be able to use this device with my lab 6506E? There is no hard drive attached to the module -- have these always come with harddrives for the software image?
Thanks in advance,
Brandon
Re: NAM-2 questions
once you get to the maintenance partition, you can download from ftp the application image for nam.
Refer to:
http://www.cisco.com/en/US/docs/net_mgmt/network_analysis_module_software/3.6/catalyst_6000/quick/guide/cat6kqsg.html#wp46318
Bronze
Re: NAM-2 questions
Thanks for the response. Since this seems to have such an old maintenance partition, will I still be able to upgrade the application considering the IOS version I'm running?
Also, and this might be more important than anything, do all WS-SVC-NAM-2 modules have harddrives mounted on the module itself?
Re: NAM-2 questions
All the nams have HDD mounted and you cant replace them.
You should be able to upgrade the maintenance partition.
Download the newer version of maintenance from:
http://www.cisco.com/cgi-bin/tablebuild.pl/ws-svc-nam
141
