02-20-2008 12:17 AM
I need to upgrade a NAM-2 from 3.5 to 3.6(1a). My question is, if I do this upgrade, what do I lose?
Do I lose my configuration of my NAM module? Do I lose nothing, do I lose data?
Thanks for the response.
Kr,
Dario
Solved! Go to Solution.
02-20-2008 09:25 AM
Technically, you shouldn't lose anything. However, there have been some upgrades that corrupt the flash which means you lose your configuration. Therefore, you should do a config backup before performing the upgrade. If something goes wrong, you can erase the flash and restore the saved configuration.
02-20-2008 09:25 AM
02-21-2008 03:30 AM
Thanks for the response!
