Naming Conventions
What do you think about the following naming convention....
L1-1-500-1-4-5124
L=facility
1=building
1=floor
500=room
1=rack
4=position on rack
5124=x.x.5.124 (last two octets of IP)
It makes it easy to troubleshoot using monitoring tools. If a device goes down, I can tell easily see the IP and location information, and respond accordingly.
Does this scheme violate good security standards?
What conventions are common in your experience?
1 REPLY
Re: Naming Conventions
We use one that is similar to yours so I would say it looks good. Concerning security, it's just the host name and as long as your securing your monitoring app, you should be good.
Hope that helps.
244
