NAT Problems with Accessing the Router ASA 5505
First off, let me apologize for pulling such a bone-headed beginner's mistake, but after all, I am brand new to the world of Cisco routing and networking in general.
I was attempting to create a route to a wireless router that resides on a subdomain and I ended up blocking direct access to the router.
The Cisco router's internal IP address is 192.168.1.1.
The Linksys wireless router that I was trying to link to is 192.168.1.135.
The subdomain under the wireless router is 192.168.3.x, with the router being 192.168.3.1.
I was able to connect to the router through Windows HyperTerminal, and when I run the show nat command, I can see my error.
Below I'll post the results of the show nat, but can anyone here help me to delete that one section that is causing the problems?
The router is an ASA 5505. The network is working fine, and so is the VPN client. The only problem that I'm having is that I can't connect to the router itself over the network.
Here is the result of the show nat command with the problem line starred:
Router1-ASA5505# show nat
NAT policies on Interface inside:
match ip inside 192.168.1.0 255.255.255.0 inside 196.0.0.0 255.255.255.0
NAT exempt
translate_hits = 0, untranslate_hits = 0
match ip inside 192.168.1.0 255.255.255.0 inside 192.168.2.0 255.255.255.0
NAT exempt
match ip inside 192.168.1.0 255.255.255.0 outside 196.0.0.0 255.255.255.0
NAT exempt
translate_hits = 504, untranslate_hits = 239
match ip inside 192.168.1.0 255.255.255.0 outside 192.168.2.0 255.255.255.0
NAT exempt
translate_hits = 2965, untranslate_hits = 226
match ip inside 192.168.1.0 255.255.255.0 _internal_loopback 196.0.0.0 255.255
.255.0
NAT exempt
match ip inside 192.168.1.0 255.255.255.0 _internal_loopback 192.168.2.0 255.2
55.255.0
NAT exempt
match tcp inside host 192.168.1.100 eq 3389 outside any
static translation to xxx.xxx.xxx.xxx/3389
translate_hits = 21, untranslate_hits = 353
*** match ip inside host 192.168.1.135 inside host 192.168.3.1
static translation to 192.168.1.1
translate_hits = 0, untranslate_hits = 3045 ***
match ip inside any inside any
dynamic translation to pool 1 (No matching global)
match ip inside any outside any
dynamic translation to pool 1 (xxx.xxx.xxx.xxx [Interface PAT])
translate_hits = 1520191, untranslate_hits = 174412
match ip inside any _internal_loopback any
no translation group, implicit deny
policy_hits = 0
Thank you in advance for any help leading to resolving this problem.
-Greg
1 REPLY
Silver
Re: NAT Problems with Accessing the Router ASA 5505
Use this configuration guide .
Cisco ASA 5500 Series Adaptive Security Appliances
http://www.cisco.com/en/US/products/ps6120/tsd_products_support_configure.html
586
