nBAR on 871 - no http match?
Am I crazy, or does nBAR not recognize http traffic on an 871? a 'show ip nbar port' does not list http. It definately shows up on my 1811 router, but not the 871. only secure-http. what gives?
i'm running c870-advipservicesk9-mz.124-9.T1.bin
Re: nBAR on 871 - no http match?
hi monks
Can you try show ip nbar protocol-discovery with enough options as per your requirement..
check this link for the available options..
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124tcr/tqos_r/qos_s2ht.htm#wp1162131
regds
Right, i know the commands, it's just that http doesnt exist.
cisco871#sh ip nbar port
port-map bgp udp 179
port-map bgp tcp 179
port-map cuseeme udp 7648 7649 24032
port-map cuseeme tcp 7648 7649
port-map dhcp udp 67 68
port-map dns udp 53
port-map dns tcp 53
port-map edonkey tcp 4662
port-map finger tcp 79
port-map gopher udp 70
port-map gopher tcp 70
port-map imap udp 143 220
port-map imap tcp 143 220
port-map irc udp 194
port-map irc tcp 194
port-map kerberos udp 88 749
port-map kerberos tcp 88 749
port-map l2tp udp 1701
port-map ldap udp 389
port-map ldap tcp 389
port-map mgcp udp 2427 2727
port-map mgcp tcp 2427 2428 2727
port-map netbios udp 137 138
port-map netbios tcp 137 139
port-map nfs udp 2049
port-map nfs tcp 2049
port-map nntp udp 119
port-map nntp tcp 119
port-map notes udp 1352
port-map notes tcp 1352
port-map novadigm udp 3460 3461 3462 3463 3464 34
port-map novadigm tcp 3460 3461 3462 3463 3464 34
port-map ntp udp 123
port-map ntp tcp 123
port-map pcanywhere udp 22 5632
port-map pcanywhere tcp 65301 5631
port-map pop3 udp 110
port-map pop3 tcp 110
port-map pptp tcp 1723
port-map printer udp 515
port-map printer tcp 515
port-map rip udp 520
port-map rsvp udp 1698 1699
port-map rtsp tcp 554
port-map secure-ftp tcp 990
port-map secure-http tcp 443
port-map secure-imap udp 585 993
port-map secure-imap tcp 585 993
port-map secure-irc udp 994
port-map secure-irc tcp 994
port-map secure-ldap udp 636
port-map secure-ldap tcp 636
port-map secure-nntp udp 563
port-map secure-nntp tcp 563
port-map secure-pop3 udp 995
port-map secure-pop3 tcp 995
port-map secure-telnet tcp 992
port-map smtp tcp 25
port-map snmp udp 161 162
port-map snmp tcp 161 162
port-map socks tcp 1080
port-map sqlserver tcp 1433
port-map ssh tcp 22
port-map syslog udp 514
port-map telnet tcp 23
port-map xwindows tcp 6000 6001 6002 6003
it looks like http traffic is just showing up as 'unknown'
cisco871#sh ip nbar prot top 5
Vlan1
Input Output
Protocol Packet Count Packet Count
Byte Count Byte Count
5min Bit Rate (bps) 5min Bit Rate (bps)
5min Max Bit Rate (bps) 5min Max Bit Rate (bps)
unknown 64178 88260
4945906 54613106
7000 102000
16000 139000
418
