NBAR x NETFLOW
aamaral2006
Today I use NBAR, and it works OK, We will implement the NETFLOW.
Can the Netflow replace the NBAR ?
I mean, will the Netflow show all information about applications that the NBAR shows ? . Or NBAR and NETFLOW are complementary management tools ?
TKS
Alexandre
Jason Davis
They are pretty complimentary...
This might help you with NBAR
http://www.cisco.com/en/US/prod/collateral/iosswrel/ps6537/ps6558/ps6612/ps6653/prod_qas09186a00800a3ded_ps6616_Products_Q_and_A_Item.html
This is helpful for Netflow
http://www.cisco.com/en/US/products/ps6601/prod_presentation_list.html
Netflow has very specific applications that it can classify. Sometimes the 'true' determination is left for the netflow analyzer (NMS application) to handle.
Netflow provides details about network traffic, where you can filter the search by the IP
address, source/destination, port, AS... so you can isolate which user starts some connections.
NBAR is a classification tool for applications, more for upper layers (4-7), especially a few stateful protocols.
