Highlighted
Community Member
NCS appliance not access after rebooted
Hi Guys,
I have one ncs appliance was working fine but after i reboot it i couldnt be able to access it through web. I can access it with cli and i saw some ncs service not running. The output of ncs status is attached with pic.
Thanks for all
Mohammad saeed
Community Member
Re: NCS appliance not access after rebooted
I don't see any attachment or command output. I'd check to see if the application status was reporting as running. 'show application status ncs'. If it is stopped you could attempt to start it with 'application start ncs'. It may be wise to grab a show tech before hand though to see if there are any issues with the server we could learn about beforehand.
Community Member
TABUK-NCS/admin# show application status NCS
Health Monitor is running, with an error.
initHealthMonitor(): can not start DB
Ftp Server is running
Database server is stopped
Tftp Server is running
Matlab Server is Stopped
NMS Server is stopped.
CNS Gateway with port 11011 is down
CNS Gateway SSL with port 11012 is down
CNS Gateway with port 11013 is down
CNS Gateway SSL with port 11014 is down
Plug and Play Gateway Broker with port 61617 is down
Plug and Play Gateway config, image and resource are down on https
Plug and Play Gateway is stopped.
SAM Daemon is not running ...
DA Daemon is not running ...
Syslog Daemon is not running ...
Is it working?
Silver
 - Try  the reboot again, and follow the boot process; watch out for errors, if any.
M.
Community Member
I rebooted twice but didn't see any errors!
Silver
 - If the problem, persists, then it seems that your Prime installation got corrupt -> re-install cisco-prime and restore data from a recent application backup.
M.
Community Member
How to reinstall it ? Through ncs reinstdb?
Silver
 - You could try that, but you will be  re-initializing the database only -> meaning issue at least an ncs stop followed by ncs start ,and last but not least , ncs status, afterwards; if problems are still not resolved , you will need a complete re-installation of your Prime-host.
M.
Community Member
I tried to restart the ncs but not working. How to reinstall it again I am using appliance and already has the image!
Community Member
I don't know what version of ncs you're working with, but I'd just start over from the beginning with the install guide and like someone else said, restore from backup once you're reinstalled.
Community Member
I have 2.1 and i remove ncs then i tried to install it again gave me manifest file not found?
Community Member
Are you trying to re-install on the original vm, or creating a new one from the ova file?
166
