Community Member
Need help, looking for a router which can do...
Hi guys, need some help here. I am looking for a router which can do the following task and features, please advice if there's any router match with my requirement.
1) The Cisco router must be able to perform dynamic bandwidth partition
where certain IP range is allocated to certain percentage when it comes to
bandwidth burst.
In normal situation, if the lower priority partition is not used, the
higher priority partition can burst to other less priority partition.
2) When the current connection is down , The router will trigger the ISDN connection automatically.
Pls advise.
Thank you.
1 REPLY
Community Member
Re: Need help, looking for a router which can do...
Any Cisco ISR router should be fine, but you should also check on the traffic it can support on WAN based on your requirement.
Cheers,
Naveen
107
