01-03-2006 08:08 AM
Folks,
I just installed RME 4.0 on windows 2003 server with english locale.
I am getting an error everytime i try to launch RME. The error says:
"Licensing server is down, please check License.log for details"
My locale is US english and i am installing trial version of cisco works
with common services and RME only.
Any help would be highly appreciated, I will surely rate this post.
01-03-2006 08:45 AM
I believe the License.log is located in CSCOpx\log
What does it say?
Also, open a DOS shell and issue the command (case sensitive):
pdshow LicenseServer
What does it say?
01-03-2006 09:09 AM
01-03-2006 09:31 AM
Both look good.
What applications (and versions) do you currently have installed on this server?
01-03-2006 09:38 AM
Windows 2003 server dual boot with xp. Nothing else on 2003. I specially installed 2003 for Cisco works.
I have the trial version of Cisco works.
01-03-2006 09:39 AM
By the way i only have 512 MB of memory in the machine, would that cause a problem?? All Ciscoworks services start automatically without problem.
01-03-2006 09:58 AM
Yes, that would cause a number of problems. The minimum requirement is 2 GB, and it really won't run on a box with less than 1 GB.
01-05-2006 02:25 AM
Hi parwal,
Try this
pdterm LisenceServer
pdexec LisenceServer
This can solve ur problem..
Suhas
