Webcast-Catalyst9k
Need some Help CISCO 6504 SNMP???
We use a CISCO 6504 with a single SUP 32. Is there any specific SNMP trap and OID if the SUP 32 goes down or fails??? Also i need one for the system reboot.
Thanks!!!
1 ACCEPTED SOLUTION
Re: Need some Help CISCO 6504 SNMP???
For a module going down, the switch will send a moduleDown trap from the CISCO-STACK-MIB.  This can be enabled with the "snmp-server enable traps module" command.  For a reboot, there is the warmStart and coldStart traps.  These are enabled with the commands "snmp-server enable traps snmp warmstart" and "snmp-server enable traps snmp coldstart" respectively.
1 REPLY
374
