Webcast-Catalyst9k
Need to edit or export WLAN Template in Prime 2.0
Hello everybody,
we updated from Prime 1.3 to 2.0 to have the new input field for the WLAN-ID in the WLAN template, unfortunately it works only with new templates, not with already existing templates.
Is it possible to export,edit and import templates by XML like in LMS4.x ?
Are those templates somewhere in a format that can be edited ?
Would be really great if editing is possible, otherwise we must create 35 new WLAN templates with all the WLAN settings again, just to have the correct WLAN-ID added.
Thanx in advance for hints and help.
Everyone's tags (4)
136
