Webcast-Catalyst9k
Need to get scripts for DFM to respond. Remedy connector?
I am trying to get DFM to perform scripts when an event happens, but I have found no none nada documentation on this. I have my old hpov scripts and dont know if they will work. Does anyone have anything? I am also looking for the CW LMS to Remedy connector for auto ticket generation.
Re: Need to get scripts for DFM to respond. Remedy connector?
This is not supported. However, you could build a solution using the Syslog Notification feature. You could log the syslog messages to a server which would then spawn a script upon receipt of certain messages. The syslog-ng daemon for UNIX is capable of doing this. I haven't heard of any customers doing this, however.
I see, is this for the scripts in DFM or the auto ticket connector to a remedy system?
I see NCM has a remedy connector that Cisco sells so I thought they would have done that for the CW system.
Richard
There is no script support for DFM. The only external notifications DFM can generate are emails, syslogs, and SNMP traps.
121
