08-26-2016 12:25 AM
I have WS-C2960S-48TS-L switch and it's SW Version is 15.0(1)SE2.Does this switch has feature 'netconf over sshv2' (Means in 15.0(1)SE2 sw version)?. Or, Do i need to upgrade to specific ios version for this mentioned feature ?
08-26-2016 09:15 PM
Hi jay.ganatra@ein,
Looks like this feature is not supported on the WS-C2960S-48TS-L, you can take a look a little bit more to this here:
You can do a search with the feature netconf over sshv2 and this is going to show you all the platforms and software versions that supports this feature.
Hope this info helps!!
Rate if helps you!!
-JP-
09-22-2016 12:54 AM
Hi ,
http://tools.cisco.com/ITDIT/CFN/jsp/by-feature-technology.jsp
Adnan
