Community Member
Netconfig gives funny error
Hi guys,
I want to deploy some tacacs+ commands unto several switches and i tried this using netconfig and because of the peculiar commands for my deployement, i had to create a new task and deploy it on all switches.
but i got thsi error from netconfig.
*** Device Details for XXXXXXXXXXXXXXX ***
Protocol ==>
Message: ERROR:RME_CDL1021:No command generated. There are no commands to deploy.
Pls help
1 REPLY
Re: Netconfig gives funny error
The commands you have selected may not be applicable for this device, or this device may not be supported. You need to provide more details as to exactly what device this is, and what commands you are deploying, and how you set up your custom template.
If this information is too sensitive for you to share on a public forum, consider opening a TAC Service Request, and provide the data there.
121
